wheel bearing
marty pierce
i think my right wheel bearing is going bad evertime i turn left i hear a low noise like something is not rolling smooth. also a tap noise when hitting a pumb in the road like speed pump size if anyone else had this problem let me know if need change bearing or hub assemply.?
its a bearing/hub setup.
did mine at the first of the summer.
RockAuto, a vendor here, had the best price. their service is right there with our other vendors, great!!!
plus they are Timkin with sensors
wheel bearings
thanks alot....really appreciate it..monday replacing front rotors and brake pads will probably work out for the bearings to get replace too.
thats when i found my right front bout to shoot craps.
had her apart for front brake job & turned the hub & could hear the little balls clickin:mad:
Do both of them. Mine went out, replaced it. nextmonth or so the other was bad.
Spend the money now and fix them both if you can.
When the truck is in the air spin both tires and listen for a cracking popping sound from both, plus check how free they spin.
