nycstev
Where is this? I would like to disable fuel system before compression test.ANy
photos?
photos?
nycstev said:Where is this? I would like to disable fuel system before compression test.ANy
photos?
Thanks!:rock:rottenronnie said:Take the fuse cover off and turn it over. There should be a map inside. I pull #2 (Engine Control Relay) and #57 Engine Control ASD when doing a comp. test.
The Pump Relay is #58 but I only ever pull the (2) mentioned above. No harm in pulling Relay #58 if you like.
Rotten
nycstev said:Thanks!:rock:
N ext question ... whats the best way to find TDC for leakdown test
