SRT-10 Ralph
I love photoshop
I believe he has a 2/3. Is anybody running a 4/6? Maybe 2" springs with 2" DJM control arms, drop block with shackles.
Hey Kyle, did you still bottom out with the notch? Did the stock shocks work well? Any tire rub on the rear fender lips? I'm assuming there was wheel hop/axle wrap issues after removing a leaf? How was the front dropped?
3-5 is what i got
no just added another spring and added bump stops. so she just rides like a stiff sports car and has never touched the bump stop. i love it i have zero body roll
On the front, are you talking about the black Energy Suspension bump stops that have ridges on them so you can trim them down?
So 3inch spring and 5 inch blocks?
Are you still running the stock driveshaft? Any pinion angle issues? Those are 305/40-22's right?
oh lol i forgot about to put that in haha had that done also...like i said pain in the ass
Raymondwebb: where do you get your drive shaft shortened and how much had to be removed?
Also is anyone running the DJM 2" or 3" lower control arms?
You rang? Yeah I have 2" djm's, need to get some taller bump stops though because my wheel well liners are ruined from it bottoming out....of coarse if I changed the 9year old shocks that might help too.... I have 1.75" blocks in the rear so it has a goofy looking rake to it instead of being level but I've been to lazy to pull the blocks to see what size locating pin we have so I can order some 3" angled blocks.....I think arrestmered04 is running those control arms, maybe he will chime in.
the front does not rub due to regular bump stops that you can buy at your local autozone....on the rear its 5 inch blocks had to flip the springs installed bump stop blocks that came with the kit and removed one of the lower rated springs on each side then installed a thicker more weight rated one off a wrecked srt10 i found to get parts off of outta junk yard. my coils and shocks are mcgaughys but i dont think they sale the 3-5 anymore think they sale the 4-6 which will not work oh and i also had to have the exhaust reworked for clearance....took forever to get right and ended up with almost 2k in by the time i got it right with no issues. would i do it again???????? HELLS YEA!
