Would they fit or no, they look sharp saw an orange one on the truck.Sharp.
DevilDawg3097 said:dammit. ok will 18's go over the fronts or will i have to go to 19's?
you can only remove and replace certain parts on your vehicle for stock mods.So I know my truck weighs 5190, I figure I can get off another 100lbs with different rims and tires, the damn stock ones weigh as much as the mack tires I put on our trucks at work, damn. so only 20's will work. Those are still lighter, then I'll go 19 in back and keep my 17's for the strip.Whitesnake said:22's only don't go smaller!
why what are you doing?
20 and bigger...look at your spare
nopeARRESTmeRed04 said:i thought 18's would fit the front???:dontknow:
even if the rims were big enough in diameter, i think the 5 x 4.5 vs our 5 x 5.5 bolt patern would get ya.DevilDawg3097 said:Would they fit or no, they look sharp saw an orange one on the truck.Sharp.
kick ass. 19 it is.thank you:burnout: :burnout: :rock: :marchmellow:505'sFastestViper. said:19 will fit the fronts and 17s will fit the rear
Thats when you have to make a decision of looking good or goin fast. I prefer speed to looks plus they don't look to bad when I am done Ill post picks. We don't have ferraris or porsches so your not gonna get both. Plus you will just be seein my back end anyway.:burnout: :burnout: :thrasher: :bootyshake:Venom Power said:WTF are you doing? Your truck's look will change dramatically with even 20's on it. Make sure you KNOW what it will look like because you may not be happy with the end result. Just go with lighter 22's if weight is the issue. I would only put on up to 23's if I were changing the wheel diameter..
YESSSSSSSS, those wher 20's If I recall right, where can I get those I can not find them anywhere.:rock: :rock: :rock:kyle's srt10 said:
