Was wondering if anybody knew how to polish or with what to polish windows with light scratches. My driver side window has scratches (over time) from rolling my window up and down when there was light dust and dirt.
i cant remember the name of it but we have some at work if nobody gets back to you then i will try to figure it out for you tomorrow
That is rare............is it some sort of grime that emmulates scratches ..............perhaps..? try a brand new razorblade with dish soap and water one direction only, down .............the only other option is a scratch remover machine, never seen used on concave glass, just flat plates, replacement of window with new piece is $$ , but is probly the best way to go..............
Good luck............the compound actually removes the scratch just takes forever, and most important dont do further damage......:rock: :rock:
That JANVIL looks like good stuff :rock: I just haven seen anything that is more easily available like at a autozone or wal-mart. Wonder if anyone knows of some type trick, I heard to use a rubbing compound, but think that it would make more scratches :dontknow:
That is a compound, engineered for scratchs on glass............there is many products...chemicals and fine compounds combined ....good luck again on yur quest...............:rock:
Im seriously gonna look into that stuff, like earlier just wondering if there was something like a trick or other product that I can find locally before I order it. But if not, im gonna try that JANVIL out. And its the Autobot symbol, im a Big Transformers fan
http://www.eastwood.com/glass-polishing-kit-pro.html They make a bunch of different kits depending on what you need.
You must understand that any compound that takes out scratches in glass, takes forever to do it. It is a very slow process. And you must also remember that what you are doing is wearing away glass to get to the bottom of the scratch. Well when you change the thickness of the glass you change the clarity of your vision through it. If the scratches are very light, you shouldn't have any problems. But if they are deep, you will have problems. Good luck, and take your time. Bill.
There light scratches...just many of them....we just have this fine dust that gets on out vehicals....
