Venom Power
So, I was driving yesterday with OSO and he noticed as I dropped a couple gears and mashed the gas #1900's rear end would sway slightly. I took her back home to get the SRT-8 but before we left he looked under the bed and noticed one of the U-bolt nuts had backed off significantly. He took a ball-peen to it and, with a slight tap on the aluminum block, showed how the block was jumping around in place, held only by its retaining/centering pin. I tried to tighten the nut this morning but it was stripped (just spinning in place).
I took her to my local suspension shop where they informed me that the U-bolts were too small/thin for that application. "But," I said, "That's a custom X-Metal drop kit." No that didn't hold weight at all. The dude showed me how the rest of the U-bolts were barely holding on and were weak. He immediately ordered a thicker set of U-bolts custom made to order out of harder metal. The aluminum blocks will also be upgraded to handle the force that would have done me in if I had hit the track with the drop parts as they were.
:dontknow:I don't know how many of you out there still use X-Metal as your 10's lowering kit. I say you should take heed and monitor your U-bolts every now and then. My plans now will be to hit up JTSVP for a "Stinking" deal on a drop kit.
