Yep, that's exactly how mine is.When the engine was stock, mine was 75 cold, 35 at idle (warmed up) and 60 at 2800 (warmed up).
Yeah mine reads 75+ when coldJust fired up my beast for the first time, the oil pressure was running at 70psi at idle. I'm running 0-40 Mobil 1 with a Mopar filter, seams high to me....
Like he saidYep, that's exactly how mine is.
You mentioned that you were using a mopar filter was it the VIPER designated filter or the SRT filter?Just fired up my beast for the first time, the oil pressure was running at 70psi at idle. I'm running 0-40 Mobil 1 with a Mopar filter, seams high to me....
That is my point these 10's require a VIPER filter other than the cheap stuff on the market.High pressure is good! these truck were known to blow off the cheap oil filters, occasionally.
That should cover all eventualitiesThe wix is good for 200 psi (burst)
I'll just leave that to the trained professionals (don't try this at home)Yes, a WIX should be good and safe.
I'm at 100 psi on a cold start but still a long way from blowing a filter off the base.
It's amazing what a mess that makes.
