Soapy00
It's cold as a witches teet here and the truck won't start this morning, won't turn over with the start button...any ideas? Should I jump it?
I've jumped mine without issue. Just assume it may need jumped when you leave your next stop.
See post #1 .... Won't crank over with the start button.......... IF auto tranny, try it in Neutral... wiggle the shifter. might be the neutral /park switch. If it is STD tranny, might be the clutch switch. Providing there is enough power in the battery, check the headlights are fairly brite. If not, give it a jump..have you tried rolling it over with the start button?
