Truck won't turn over, battery seems fine
Soapy00
Marcus Hook, PA
It's cold as a witches teet here and the truck won't start this morning, won't turn over with the start button...any ideas? Should I jump it?
I've jumped mine without issue. Just assume it may need jumped when you leave your next stop.
Yessir you can jump it. Likely your battery took a dump. They like to go out in extreme hot/cold climate changes. Look for bulged sides of battery as telltale sign it needs replacing.
have you tried rolling it over with the start button?
See post #1 .... Won't crank over with the start button.......... IF auto tranny, try it in Neutral... wiggle the shifter. might be the neutral /park switch. If it is STD tranny, might be the clutch switch. Providing there is enough power in the battery, check the headlights are fairly brite. If not, give it a jump..
Could also be a bad start button, I've seen that before.
There's finally a recall on the clutch switches but they haven't pruduced a solution yet? Hmmm? C'mon Chrysler!
