I think I may have a air leak through the throttle body shaft. With a stethoscop it sounds like the high pitch sound is coming from it. Anyone know if there is a replacement seal or oring?
Well I am going to take the throttle body off after work and take a look at the seals and take pictures than. As for a video of the sound I have is video.
I had to bring my truck in for the air bag recall to the dealership so I had them take a look they told me it was the o-ring gasket from the TB to the Intake and wanted $200 bucks to replace it plus the $167 for the diag check. I paid the diag check then quickly emailed Tony from JTS Performance he hooked me up with a new gasket. I changed it but still squealing bad. Now I am being told its the seal to the throttle body bearing letting air in. :dontknow: So was looking around to see if I can replace that seal. Hoping someone on here maybe one of the vendors could hook me up.
there isn't a throttle body shaft seal, only a bearing, one on each side of the throttle body, from there the tps seals one one side, the shaft the other, then a gasket that is oringed into the intake, does this happen only at tip in? if so it could be the nos ports on the throttle body itself, it will cause a slight whistle on tip in
Sounds good. Thanks for all the help. :rock: I can hear the sound all the time expect at WOT but then my exhaust is so loud who knows. :burnout: :rock::rock: If it is the NOS ports just going to have start saving to install a NOS system, don't want them wasting there. :rock:
A good way to check for vacume leaks is to spray a little carb cleaner around the area you think it's leaking from. It should get sucked in & raise the idle a little bit.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
