Catylitic convertor code
New2srt10
06 srt10 qc threw a bad convertor bank 1 side so if I put high flow cats on will it still throw a code for bad convertor?
How long has it been since your o2 sensors were changed?
If the answer is NEVER, I'd start with replacing those.
Yeah thought of doing that first cheaper and easier lol. Isn't there a code that would show up for bad o2 sensors?
None of the onboard diagnostic systems always point to the exact problem, even today's.
If you pound on the cat with something like the palm of your hand, it should be quiet inside the can. If it sounds like it is full of rocks, it is done and needs to be removed or replaced.
Check the wiring harness on the rear passenger side of the engine, to make sure it has not touched the manifold or header (if you have them). Check the leads going to the O2 sensors as well. I had trouble with one of my leads back in the day.
