GADodgetech
I can do it in 45 mins :aetsch:
ram_vs_cougar said:Ok will read over the article and see what good info is in it... Ok if i remove the door completly will it start to blow more air inside the truck lilke it should or will it just continue to blow the same? and whats the $120 for epoxy and ???:dontknow: just curious because i'd rather fix it my self rather than spend 1500 dollars.
GADodgetech said:I can do it in 45 mins :aetsch:
OSO said:
Ha it aint hard bro, if you got two guys on each side you can bust it out in no time. just remeber, you dont have to fully remove the dash just lean it back. Its only nuts and bolts dude :rock: :rock: :rock:ram_vs_cougar said:Seriously? :dontknow: I need to get with you then so I can knock this thing out lol
wesalbert said:$120 is for a new door made by some company.
The Epoxy is just how I fixed mine. It was cheap and easy.
IF you just take out the door, it will blow more. BUT it is brining in air from outside as well as inside.
GADodgetech said:Ha it aint hard bro, if you got two guys on each side you can bust it out in no time. just remeber, you dont have to fully remove the dash just lean it back. Its only nuts and bolts dude :rock: :rock: :rock:
Just drop the steering column and you'll be good, im originally from kingsland ga but I now live in NCram_vs_cougar said:lol sound easy finding help isnt easy all my mechanic buddys back in LA. Oh ok i was thinking that you had to take everything out, radio, steering wheel, etc but if it will be enough room to just lean it forward and fix it then its not that bad. Where are from in GA?
GADodgetech said:Just drop the steering column and you'll be good, im originally from kingsland ga but I now live in NC
