black pearl
I am looking into rebuilding the motor in my 05 QC. Here is my wish list. What do you guys think, overkill, not enough, different mods?
Truck Engine Build
Forced Induction W/NOS
Goal 1000HP
250 shot nitrous
Rods:
K1 or Oliver
Pistons:
Wiseco or JE (Coated ?)
Crankshaft:
Ground, polished & balanced
Dual key crankshaft
Mains:
Billet Main caps
Coated Bearings
ARP Bolts
Stock Heads:
Stainless Steel exhaust valves
Port matched
Chromalloy pushrods
Performance Hydraulic Lifters
Performance valve springs and retainers
ARP Head Studs
Miscellaneous:
ProCharger F-1A Supercharger system
Minimal bore and Hone the block for precision roundness
9.2 to 1 ratio
Parallel deck block
File fit piston rings
Oil pump modification
Line Boring Mains
Fuel pump upgrade
Crower or Mopar camshaft
Block stress relived
Static and Rotational Balancing
Port matched intake
Supercharger V-belt drive damper
Cloyes true roller timing chain
Larger fuel rails and injectors
Truck Engine Build
Goal 1000HP
250 shot nitrous
Rods:
K1 or Oliver
Pistons:
Crankshaft:
Dual key crankshaft
Mains:
Billet Main caps
Coated Bearings
ARP Bolts
Stock Heads:
Port matched
Chromalloy pushrods
ARP Head Studs
Miscellaneous:
9.2 to 1 ratio
Parallel deck block
Line Boring Mains
Fuel pump upgrade
Port matched intake
