Engine Build Ideas
black pearl
Shake & Bake, CA
I am looking into rebuilding the motor in my 05 QC. Here is my wish list. What do you guys think, overkill, not enough, different mods?
Truck Engine Build
Forced Induction W/NOS
Goal 1000HP
250 shot nitrous
Rods:
K1 or Oliver
Pistons:
Wiseco or JE (Coated ?)
Crankshaft:
Ground, polished & balanced
Dual key crankshaft
Mains:
Billet Main caps
Coated Bearings
ARP Bolts
Stock Heads:
Stainless Steel exhaust valves
Port matched
Chromalloy pushrods
Performance Hydraulic Lifters
Performance valve springs and retainers
ARP Head Studs
Miscellaneous:
ProCharger F-1A Supercharger system
Minimal bore and Hone the block for precision roundness
9.2 to 1 ratio
Parallel deck block
File fit piston rings
Oil pump modification
Line Boring Mains
Fuel pump upgrade
Crower or Mopar camshaft
Block stress relived
Static and Rotational Balancing
Port matched intake
Supercharger V-belt drive damper
Cloyes true roller timing chain
Larger fuel rails and injectors
Just a few changes and the more I think about it the more the list will change.
Truck Engine Build
Goal 1000HP
500 Shot capable Direct Port Nitrous
Rods:
Oliver
Pistons:
JE Coated
Crankshaft:
Ground, polished, balanced and nitrate it.
Dual key crankshaft
Mains:
Billet Main caps
Coated grooved Bearings
ARP Bolts
Stryker Heads with Jessel combo:
ARP Head Studs
Miscellaneous:
8.2 to 1 ratio
Parallel deck block
Line Boring Mains
Fuel pump upgrade
Custom ground camshaft
Hogans intake
I thought you had a Paxton on it when it blew :dontknow: If so and you want to get rid of some parts pm me:D
The key word is HAD:D I only put it on because of the trip to Sac.:eek: Will be removing the Paxton soon. I am going with the ProCharger setup from Justin:rock:
ya if your going procharger you definitly need to go striker or a good set of fully ported stockers.. get em flowing atleast 315 cfm
Talked to Kevin at EED the other day. He has a few trucks that he is working on now but may be able to work on mine also. He will call back on monday with his suggestions and we will see where to go from there.
