attila said:what is this bracket for?
and the heat shield? is it for the steering link?
thanks
Silverback said:It's always easier when you have a beautiful lady to help you out. :congrats:
Sorry, I should have added this tip earlier.
For holding the gasket in place, cut a piece of copper electrical wire about 3 inches long. Then strip it so you have the individual copper strands. Use the individual strands to tie the gasket to the header. Since the strands are only about .003 thick, you can actually leave them in place without any ill affects.
She is a cutie!!!Prof said:That's Luanna!
One of the major reasons the two of them are always welcome at my house!
thanks
attila said:Thanks for the tip Ironhead
Driver's side is done as well, still need to torque 3 bolts and reinstall all the stuff I removed
so is the ceramic boot meant for the steering linkage?
anyway I'll wrap all the stuff with low clearance with some heat shield tape and I still have some headers wrap to use for this purpose
thanks
attila said:ok, I finally started it
my sweaters smells of muscle car! ))
I think there are some leaks: I over torqued the bolts around 25-30 Lb/ft; I'm pissed off about leaks and honestly don't know what to do to fix them
should I bring her to the shop and have a check? but the good one is about 30 minutes away and I could burn the gaskets going there..
any hints?
thanks
