Hey worm if ya talking bout my 11.2 vid, if ya watch the ol girl was spinnin big ol hoosiers thru 1st and 2nd
what stinkem's said.........Stinker said:I have had the best luck with oem gaskets bro, they seem to seal the best:dontknow:
Thanks, Tony... Looks like I'll be ordering a set of OEM gaskets.Stinker said:I have had the best luck with oem gaskets bro, they seem to seal the best:dontknow:
ZCx said:went with Totally Stainless header bolts & their lock washers. the bolts are the 6 point 3/8 head. helped to get at all the bolts a bit easier with a 1/4" set up.
ZCx said:i did the retorque procedure with my Belanger headers & they still went to leakin.
went with the Cometic gaskets, but the OEM should do ya a good job. both are the MLS gaskets.
when i got the headers back off the Belanger gaskets were hard & very brittle. just fell to pieces. made clean up a breeze though.
have rechecked the bolts twice now with not a one bein loose.
be sure to put a bit of anti-seize on the bolts. i use the copper kind.
:rock: :dontknow: :rock: :dontknow: :rock: :dontknow:
time to check out the catless mid pipes now.:burnout: :burnout: :burnout:
Stinker said:So according to arp catalog the 5/16 comes in packs of 14 and about $30 a pack for the stainless 12 bolt, that sound about right?:dontknow:
Stinker said:You want the hex head or the 12 point head?
It would take about 4 days to gettem to ya, the warehouse dont stock em, so they would come straight from arp bo, and that usually takes an extra day or so, i want to double check the price too
I wouldnt do any hard prolong downshifting with a leak at the head, it's possible to suck cold air in and burn the valves.portlandsrt said:Quick Question.... Seeing as I probably won't be receiving the bolts for a week, can I do any damage by driving around with a leaky gasket?
Westxsrt10 said:I wouldnt do any hard prolong downshifting with a leak at the head, it's possible to suck cold air in and burn the valves.
