lakeman
Has anyone removed the inserts for underhood cooling.
+1
The grill block inserts (block offs) are a huge part of the overall performance package of the truck. The SRT team did their homework on this one.
More than enough air passes through the front grill. The SRT team determined how much could be blocked off w/o sacrificing cooling. Actually, they promote cooling. Its called "diffusion cooling". The air coming in slows down after passing through the inserts which is a high velocity small opening. Then, with the square area of the core support being larger, the air slows way down and extracts more heat from the radiator. As mentioned above, the hood scoop draws the hot engine air out (it is in a low pressure zone). That not only assists with cooling, it assists with handling. At high speeds, it will minimize air "ballooning" (or damming up) in the engine bay, which make the splitter on the front fascia more effective providing down force.
The biggest benefit from the block offs is aero. More air around the vehicle reduces cD. The less air through the grill, the faster you can go. (think NASCAR super speedway and the "tape" used to block grill off openings)
Cheers!!![]()
Hey, you cant be the resident town clown and provide knowledgeable insight on srt-10 rams..Please choose one..![]()
Besides, did you not know I am absolutely crazy!?!?![]()
I took mine off. I like how the CAI. gets more air with them removed.
Meh... I still don't like em...
I like being able to see my CAI tube... lol
My Cai goes all the way down to the bottom of the bumper.
And,
SOUNDS AMAZING!!!!
