Ground force rear shocks bounding
whammo
Houston, TX
Installed the ground force lowering kit, and the rear shocks are bounding bad. You go over a bump and the rear end bounds three times. Even going down the road the rear end bounds like there are no shocks installed, (not bottoming out). Is this normal and;or what can I do? It's making the truck look cheap!
stayed with the Bilstein's on mine. no probs. RC though
Did you cut down your bump stops? If not that bitch will ride rough, and you can leave your stock shocks on it if there is a shock problem. The bump stops are about 3 to 31/2 inches long, need to be cut down to 1"
It's an Rc. I didn't know if I could put the stock shocks back on which are way better. I thought maybe I would run out of shock travel before I hit the stops.
