dcrow
what type of gains would you see with a cam and port and polished heads or cam and justcleaning the heads up.
Nowwhat said:headers....
Depends on the cam and porting job.dcrow said:what type of gains would you see with a cam and port and polished heads or cam and justcleaning the heads up.
Texas Yellow Fever said:You didn't just say that did you????
Nowwhat said:ahh...for crying out loud....I have always said you need headers if you are doing a H/C package....I have also always said that you can have a paxton for the same $$ as a H/C package so why bother....
Who in their right mind would do that??! :dontknow:Texas Yellow Fever said:One question though...why not do both...:dontknow:
Heads - from some of the major compaines 3K-6.5K.dcrow said:what would it cost to port and polish the heads and the cost of the cam.
ViperTruck2933 said:I am going with a very big custom grind cam. Probably bigger than anyone else has done on the trucks. I am also upgrading to roller rockers, port matching the gaskets and intake runners, port polishing the heads and port/polishing the intake runners. I am shooting for 80-100 rwhp gain.
Agreed.Silverback said:Be careful with the cam. Bigger is not always better.
ViperTruck2933 said:Agreed.
I discussed my goals and driving habits at length with Joe Donovan. I told him I wanted to go as big as possible within the framework of those goals, driving habits and my budget. We also considered my existing mods and the other mods I am doing.
Joe then talked at length with the engineers at Comp Cams and together they came up with the grind that I am using. Hopefully it'll all come together nicely.:rock:
That's for sure. I can't wait to hear it thumpin. :burnout:Nowwhat said:80-100 is reasonable...but the lope at idle alone will be worth the price of admission....:rock:
Does he have a ported throttle body? Do you know how big the cam is?Bone said:A previous forum member installed a very aggressive cam a couple of weeks ago here with Taliban Dan. It sounds and pulls great, however the idle is rough and fluctuates.
