Help with clutch
tsmith3
Evanston, WY
So, I installed a clutch and everything went fine till I started to bleed the clutch. I couldn't get any pressure to build up on the system. I began with topping the reservoir off and let it sit for awhile. Then I had my son apply the clutch pressure while I bleed it, shut it then he would disengage the clutch. Did this about 50 times with no luck. I have no pressure whats so ever on the pedal with all this bleeding. It looked like all the air was out of the system.:dontknow:
Then I really screwed up! I took the bleed plug all the way out and line moved in the tranny. I attempted to screw the bleed plug back in but managed to drop it in the tranny. :mad:
i had this problem with mine when i changed the master cylinder, what worked for me was to grab the clutch pedal with my hand and pump it back and forth really fast, after about 10 pumps i had pressure and then i bleed the clutch the normal way to make sure all the air was out
