RedRamRules
Just finished removing the intake manifold. First and foremost, I would like to give thanks and a shoutout to Dan and DC Performance, for which this removal could not be done without. He removed the bolt which I spent 3 hours on Sunday in 5 minutes :adore::rock:
From start to finish the second time today, it took 20 minutes to remove. Not a hard job (with the exception of the one bolt). Need to clean the area underneath though. The inside of the runners and intake plenum is rough, I wish there is a way to smooth them out. Also I wonder if I can grind some of the casting lines out.
While the intake is out, should I do anything while the truck is down? All my gaskets are OK.
The last pic is the location of the difficult bolt, I wonder if I can grind the outside a little bit to give my socket more clearance.
:boxing:
:boxing:
