badmood
I was driving to work today and the truck overheated. I let it cool down and checked everything and the radiator was pretty much empty. I just had the oil changed 2 months ago and the radiator coolant was fine. I keep an eye on my fluids regulary and it has been fine. It sat for the entire month of December in garage with no visible leaks. So I filled the radiator up with water to get it to the dealer. They just called and advised they can not get it to overheat. I replied that because I put water in it. There has to be an issue because all the coolant doesn't just vanish does it. Could it may be a head gasket. I only have 26k miles on it with no issues till now. What should I watch for from the stealership. Thanks
