Remove the drain plug (lowest on the rear of the transmission) drain and ...replace it.
Remove fill port half way up the transmission drivers side...fill from the top after removing old shifter until it starts to drip from the fill port. Replace fill port plug. Install new shifter...
Drive it around a bit so that the old fluid is warmer and thinner so that it is easier to drain. Also any muck in there will be suspended in the fluid instead of settling.
