Just an FYI. Cavitating your oiling system is the beginning of your engines death. Our gear/rotor type pumps DO NOT like cavitation and are slow to recover from it.
Good luck and Cheers!
Other than keeping the oil pan full of clean, high quality oil, I think it's a really good idea to replace the 3-piece oil pump relief-shuttle with a 1-piece.
Mopar found an oscillation problem on some of the Gen IIIs with the 3-piece and made the switch to prevent problems. When there are rapid pressure fluctuations it can create weird and wonderful changes to the oil stream.
QUOTE FROM WIKIPEDIA: Cavitation is the formation of vapour cavities in a liquid – i.e. small liquid-free zones ("bubbles" or "voids") – that are the consequence of forces acting upon the liquid. It usually occurs when a liquid is subjected to rapid changes of pressure that cause the formation of cavities where the pressure is relatively low. When subjected to higher pressure, the voids implode and can generate an intense shock wave. END.
The plug is on the outside of the oil pump (Driver's side) and is where the relief lives. Although it's fairly easy to get at, it can be bitchy to remove the plug.
The Gen III is a big oil pump compared to many and with a little help, they work fine.
If you are going to rebuild, spend the cash and also upgrade to (coated) Gen IV bearings (and the required minor block mods) and if your engine can breathe properly, feel free to buzz the engine!:burnout:
As a relatively mild street version of a Gen III, I routinely buzz mine to 6600+ with no ill effects.
