AWDisuzu
i hate the rebuilding part! i need a bulletproof racecar
Prof said:... due to my current traction problems when I let the clutch out too quickly at WOT...!
That was the best piece of advice that anyone gave me, just push the shifter through the dash.SVTFreak said:my rc sounds like a auto going down the track is what i have been told by others.....and i do shift it as if to send the shifter thru the dash.....
BigRed460 said:... I am not racing this truck in any class, my goal is to go as fast as I can in a truck...
mopar_mudder said:based on my times I don't think I am missing to much, can't imagine that beating my tranny to death is going to gain me much.
AWDisuzu said:my QC shifts the fastest though.
M-22 "Rock Crusher" transmissions? (one of my personal favorites)FSTJACK said:I broke a lot of main drives and cluster gears in Muncie 4 speeds in the 60's. They were not a very strong gear box either. I broke most of them on the launch.
As requested:FSTJACK said:I have seen Trainman at Bakersfield and it was a thing of beauty to see him make a pass, powershifting.
AWDisuzu said:you could put in an auto tranny for a lot less $$$ ;-) bands are pretty cheap to replace
Texas Yellow Fever said:Yep, my thoughts exactly...and I can honestly say, I've never missed third gear... :burnout:
slow91 said:Let me play devil's advocate for a minute....please don't think I'm flaming you.
I see you have a ECM, CAI, headers and exhaust.
Blaine (svtfreak) ran an almost identical time to yours (12.7 @108) with zero mods.........and like me, he powershifts his a$$ off.....:rock:
http://videos.streetfire.net/search/srt10/0/52E30BF6-117F-4A3A-AD85-DBDD31CED304.htm
Muzzy said:If you know what you are doing and just take it to the track once in a while, I do not believe you will shorten the life of the trans noticeably. I definitely believe it is not the best way to shift your trans if you are interested in longevity. If you are building a truck to run at the drag strip every weekend, then I would ditch the manual for an auto. The auto will be faster and stronger if built correctly. Plus it would be more consistent.
I spent my fair share of time at the drag strip. I used to points race an 89' Mustang that was a 10 second car bracket car. I tried running a modified T5, but I eventually broke it. I don't think it was as much related to power shifting as running 600HP through a T5. Once I switched to a built C4, my times were more consistent and I did not break it nearly as often (only when using trans brake).
-Muzzy
FSTJACK said:Leaving on a transbrake is like being hit in the A$$ with a cannon........
Muzzy said:...That is the easiest way to find the weak spots in your drive train.
-Muzzy
