Cudajon
Does anyone else have this? It will just be squeaking at idle for a while until the truck warms up than it stops. What causes this its kind of annoying
ACE said:Check the crank pully it might be coming loose! and if it does it will take out the crankshaft to!!
mine did, it would squeek in the morning or if it sat for a while..
check to see if the pully bolt in the center of the pulley is loose.
Joe
same thing - replace the belt, no more noise.....Kwyjibo said:I battled a cold engine start-up squeek for awhile. Used WD-40 on the idler pulley and sure enough it would stop squeeking. The next time that I would start it, the squeek was even louder and would last longer before falling silent.After replacing the idler pulley and still having the squeek, I finally replaced the belt. Squeek gone! Check your belt and I hope that helps.
Cudajon said:Does anyone else have this? It will just be squeaking at idle for a while until the truck warms up than it stops. What causes this its kind of annoying
the pulley below the alternator is on a spring tensioner, put a wrench on it's pulley bolt to take the tension off the belt.... it's fun. :elefant:10banger said:Alright fellas, my truck is having the same problem. I'm trying to install my new belt and I have a question. Do you loosen the bolt on the idler pulley to take the belt off? I know this sounds like a dumb ass question but I want to make sure before I go breaking bolts.
All help is appreciated!
Same exact thing happened to me today..... damnit!!! WTF??!!:motz:HV SRT said:I replaced my belt and the noise went away until I washed the engine compartment and the noise came back. I might have to start pulling the belt before I wash it again.
