SRT-MIKE
Just purchased a set of 4:88's to replace the 4:11's on the truck. The intent was to gain low end torque at the expense of top speed that my daily driver never sees, so on the surface it appears to be a no brainer.
After doing some searches and reading old posts I realize (maybe too late now) that the story is not so simple. It's much more a matter to matching a set of gears to a vehicle, or to an application, and that just hopping the ratio to get more torque might be like barking at the wrong tree.
Something obvious that failed to register in my hardened nugget is that I will be loosing top speed in every gear, not just hi gear. That could be a problem, as I would be having to shift sooner, etc, etc.
So what I would like is some testimonials from people that have undergone the change to 4:88, are you impressed? Does the truck feel stronger thoughout? and any such things that you could share, so I can decide if to go ahead with the swap or stick with what I have.
Thanks in advance!
Thanks in advance!
