nycstev
For those of you who experience this same problem, Sean Roe wrote this regarding a fix which was just developed recently. Surprisingly this pertains even if you have a VEC unit.
Roe Racing
Re: TB with TMTS Blow
Quote:
Originally Posted by nycstev
Sean;
I have your blower installed. Notice throttle response is not as crisp when engine is hot.?whats the cause and Does a TB correct this?
Steve
Hi Steve,
We found out that the timing strategy of the stock PCM pulls a boat load of timing out as the engine intake air temp goes up. It's pulls out over twice what they do on the cars.
The quick way to correct it is to put an simple 5 to 7K ohm resistor in the wire going from the IAT sensor signal wire going to the PCM (the wire that is not blue). That makes the PCM think it's about 20 degrees cooler out and keeps the timing up better.
Beyond that, the throttle body makes a giant difference with the positive displacement blower.
Let me know if you need anything else at [email protected]
Regards,
Sean
Roe Racing
Sean;
Steve
Hi Steve,
Regards,
Sean
