Done today on a Super Flow 600 - Newest, latest and greatest flow machine. I will pick up the graph at the shop Monday or Tuesday and post it. However, wrote some of the numbers down over the phone:
Valve Lift ...Intake Stock ...Intake Ported
.500 ...........*257.6 ............285.2
.550 ...........*263.4 ............294.1
.600 ...........*268.2 ............298.0
.650 .................................300.5
.700 .................................299.4
*Stock numbers are from J&M website also on a SF600. http://jmcylinderheads.com/?page_id=12
We will try to flow another set of stockers this week. Nevertheless, numbers should be close to the same values.
Valve Lift ...Exhaust Stock ...Exhaust Ported
.500 ..........*182.4............... 208.9
.550 ..........*184.1 .............. 211.9
.600 ..........*185 ..................214.4
.650 ...................................216.8
.700 ...................................218.5
Now, I had my Roe SC Intake ported/port matched to the heads. Here are both flowed together.
Valve Lift ...Ported Heads with Roe SC Intake attached
.500 ...........282.4 (heads only 285.2)
.550 ...........289.9 (heads only 294.1)
.600
.650
.700
My numbers are with stock valves no machine work!
Now mine (stock valves 2.000"/1.580") vs. J&Ms Stage 3's with aftermarket valves (2.040"/1.600")
Valve Lift ...Mine Intake Ported ...J&M Ported with aftermarket valves
.500 ..........285.2........................ 287.5
.550 ..........294.1........................ 294.0
.600 ..........298.0........................ 300.6
.650 ..........300.5 ........................no # posted
.700 ..........299.4 ........................no # posted
.600
.650
.700
