ontariobee
Where do i find myself a set of rear wheel well liners? Everyone i find says it won't fit the srt-10's. Thanks for any help
can i see some pics? sounds interesting
Thanks for the tips guys. yea i agree i don't like the open look being able to see everything under there.
So what is the story here guys......
My 05' has them stock. No rubbing. Do some owners remove them for some reason?!?
They are definately an aero advantage having them in there.
As said above they are not made for the SRT10 but will work...You can install and drive for a while then remove and cut out the areas that rub...I did...the rub areas are behind the tire so the areas cut out cannot been seen......to me they are a must have mod....truck just looks odd with the open wheel wells...
If they do rub, I might suggest an alternative to cutting portions out where the tires rub.
Wait until the tires have touched the liners so you can see where the clearance issue is, then take a heat gun to the liner and work the material to create more clearance at the point(s) of contact.
This is what I'll be doing when mine arrive.
Just like someone from hell to want to use heat to fix something..LOL..![]()
