Hell yea!
Finally got some JTSVP parts! :rock:
I'll make it look cleaner once more parts arrive.
I gotta say, the intake was pretty easy to remove. From all the reading I have done, it seemed like it was a nightmare. Nahhhhhh...
All you use on the driver rear side bolts is a swivel head extension magnet at 90°, put the 11mm socket on the end and put onto bolt head (while holding) then take your ratchet extensions (I used 1/4" ratchet) and feed it through the top hole of the last plenum an into the socket. Breaker loose and reverse procedure. Came out super easy
The Screamin' Demon Coils weren't numbered, so I just put them on anywhere
Also Loomed the injector harness up to the clips. Clips didn't feel brittle at all.
And the TB... *whistles* what a beauty....
Quality Products and Packaging Tony... I am very impressed! :congrats:
