Plumbing the intack now and was going to install the BOV on the tube between the SC and the inlet of the charge cooler. Seems that's where they get put whenever the charge cooler is moved on top of the intake. Sound like a good spot?
I have the weld on flange that the BOV bolts to but not sure if it should be welded directly to the pipe or should it be welded to a small stand off tube to raise the BOV off of the pipe slightly? I have seen it both ways and was not sure if it made a difference either way.
Thanks for any advice!!
