Terry is going to want it back
tell her i did way to much work on it to get it here lol![]()
damn!!! only thing that could make that sexier would be if it were black instead haha
IS tghat the JTSVP extreme lowering kit?
No its the Ironhead special lowering kit ,,i made my own lowering blocks at work on a Bridgeport out of a block of aluminum , i made them for a 3 1/4 in drop and i had a set of front springs i trimmed down from my old dodge 3/4 ton truck ,,,i did buy a set of urethane bump stop from stinkolaman for the front and rearthen i took it in to a front end shop here in Houston and had them install a set of eccentric bolts and hardware on front control arms for easier front end alignment ,,
just like stock i cant tell the diff and i dont have to worry about bottoming out on a bump,,when i measured the diameter of springs they were almost the same a little bit larger diameter ,,just the 3/4 ton ones were higher than ours are,,i did not want to cut my oem ones just in case it did not work out,,,o and the cost of my drop kit ,,about 200 bucks including front end alignment ,,cant beat that bubbaNice, how does it ride with the 3/4 ton springs?
