Heads cam intake package for sale over 580rwhp
SRT10VENOMOUS
1800HP Club. And climbing
Vancover BC Canada
Fully modified heads larger valves etcetera
Custom ground cam
Fully ported intake
Bellangers
Ported tb
This package produced over 580 rwhp and runs like a champ.
Have 3k miles on package all highway driving across country
Will post full specs shortly.
Looking around 5 to 8 k depending on what's included
Is that the 11.51 1/4 at 121 full weight set up?
yes this is off my truck.. we are going to go a lil over the top this time around so starting fresh.
yes that is the 11.50 set up.. minus the internals work to help it accelerate so rapidly.. This set up with some internal mods on a dyno looks like a FI dyno chart at the rate it climbs...
You should be tearing your truck apart over the winter! Not over the few decent months of weather you have haha. So what are you doing now?
Hey guys, Ive received all PM's but have not had a chance to respond been out of town as some know, Just got in now 2am or so.. will be getting to ya hopefully tomorrow..
The new plan is a full rework and a 750rwhp goal.. and a direct port of No2 into her to bump it to 1000 crank..
Interested in the cam specs, flow numbers on the heads, and full dyno charts to show the HP and Torque curves at various RPM from 3000 to 6000 (or 6200) if possible. Also PM me your phone number, thanks. Jerry
My guy is sending all specs to me Monday. Will send ya my info soon as I get everything for ya.
750 RWHP. NA! ,:drool: this is going to be interesting!!:D
I know the 700 is possible seen it but 750 is the goal push it a I'll further. But he'll who knows. Maybe I'll get less than I've got now lol.
But there is a motor been done in the shop now. Full billet block etc and they are saying it will hit 1k crank hp. But that one is big bux
But there is a motor been done in the shop now.:elefant::elefant: Full billet block:elefant::elefant: etc and they are saying it will hit 1k crank hp. But that one is big bux
that would be sweet:rock::rock::rock:
Ok here is some info.. As well spoke to my builder and he found an early dyno sheet which will be the most relevant to you all.. as this is on a stock bottom end, and at this point has no tuning just factory computer..
This is on a Mustang dyno.. You pull this same pull on a dyno jet and you will be another 30/40hp Crank higher.. And thats they dyno ppl use for bragging rights, But if you want accurate numbers Mustang is the way to go ..
Anyhow Builder Comments below..
As for your stuff, there is some trick stuff that I did with the heads that worked and I am not in the business to let people know what we worked hard to learn. All potential buyers need to see is your dyno graph
Remember 550+ rwhp on a Mustang dyno is at least 670 hp at the crank for a Viper truck with those heavy wheels and tires etc.
There are Viper trucks with superchargers that don't make that power.
Basically, your heads flow over 300 cfm on the intake with a custom made 2.02 intake valve. Intake manifold is also ported and throttle body is modified.
The heads, manifold and cam are custom designed to work as a system on a Viper truck and intended to make good low speed torque to move the weight.
Remember the 550+ rwhp was without tuning so with tuning you should be in the 570 range and near 690 hp at 5700 rpm. That's almost 200 hp more than the stock engine.
Ok the first sheet is the 2nd page of the 2nd pull on the dyno .. The dyno pull you see here is a few hp short of the 550.. but you can see the results either way... still looking for the other dyno sheet that shows the actual results that show the 551pull.. anyhow this is what i have for now,, will post the other one up soon as i find it
Oh and remember I need no core in exchange. You get new heads with valve covers everything. Anyhow as you know I'm not to sure on the pricing so make some offers if you're interested.
