You mean slow burn race fuel, correct?
I agree with Caveman. The higher the octane the slower the burn. :rock:
Here's a quote from my quick search of the internet,lol.
Octane is the ability of the fuels ability to resist detonation. Higher octane WILL burn faster based on it's properties. Hell Nitromethane will evaporate into the air it burns so fast as well as having an explosive personality.
Wasted fuel past the compression stroke is simply power that could be made if the burn was correct for the application. Compression ratios, Combustion chamber design and efficiency all contribute to how the fuel will burn.
Listed below are the four basic qualities of fuels. As in everything, there are trade-offs. You can't make a racing fuel that has the best of everything, but you can produce one that will give your engine the most power. This is why VP produces different fuels for different applications. The key to getting the best racing gasoline is not necessarily buying the fuel with the highest octane, but getting one that is best suited for your engine.
1. OCTANE: This does nothing more than rate a fuel's ability to resist detonation and/or preignition. Octane is rated in Research Octane Numbers, (RON); Motor Octane Numbers, (MON); and Pump Octane Numbers (R+M/2). Pump Octane Numbers are what you see on the yellow decal at gas stations, representing the average of the fuel's MON and RON. VP uses MON because this test method more accurately simulates racing conditions. The conditions under which fuels are tested using the RON method are not as demanding, thus the number is normally higher than the MON rating. This leads many other fuel companies to rate their fuels using the RON in an effort to make them appear more resistant to detonation. Don't be fooled by high RON numbers or an average -- MONs are the most relevant ratings for a racing application. Be aware, however, the ability of fuel to resist detonation is a function of more than just octane.
2. BURNING SPEED: This is the speed at which fuel releases its energy. At high RPMs, there is very little time (real time - not crank rotation) for fuel to release its energy. Peak cylinder pressure should occur around 20° ATDC. If the fuel is still burning after this, it is not contributing to peak cylinder pressure (which is what the rear wheels see).
3. ENERGY VALUE: An expression of the potential energy in the fuel. The energy value is measured in BTUs per pound, not per gallon. The difference is important. The air:fuel ratio is expressed in weight, not volume. Generally speaking, VP's fuels measure high BTUs per pound and thus, have a higher energy value. This higher energy value will have a positive impact on horsepower at any compression ratio or engine speed.
4. COOLING EFFECT: The cooling effect on fuel is related to the heat of vaporization. The higher a fuel's heat of vaporization, the better its ability to cool the intake mixture. A better cooling effect can generate some horsepower gains in 4-stroke engines, and even bigger gains in 2-stroke engines."
