FS: Huge SRT10 Partout, OEM and Aftermarket, Forced Induction, N20, etc.
Status
Not open for further replies.
Probably not a whole lot but there would be a gain. If the heads where gasket matched it would help a bunch.
I have an 03/04 and an 05/06 crank, both in great condition and all stock journals for sale as well. Also the pistons from Doms truck, .010 over Diamond 8.8 compression, .927 pin. One is hurt from the head gasket (diamond will make just one for under $200 most likely), the rest are in good shape, make me an offer, they are ready to ship.
How much to ship the 3:73 gears to Austin,Tx?
And is the line lock a full kit? and how much to ship that too?
Line lock kit is missing the line lock itself, they are $40 new through summit (so your still $45 less than my kit new with a bare bracket). Line lock only $37, gears only $115, Both together $140 shipped.
Justin
Listed a bunch of the OEM stuff on ebay, under seller "mopar211" all starts at a $1!!
Justin
Also have a modified big rotor oil pump with special relief valve, good for 7000RPM. Its all in a complete front cover/oil pump assembly (no water pump or fittings) $450
Also a winkle black JMB hidden coolant jug $40
Stock fuel injectors $75
Stock fuel rails modified with -6 ends on them for a aftermarket fuel system.
Powdercoated reflective chrome, never installed since modified/coated $175
Bare cylinder head set, excellent shape, no issues or blems $400
Candy Blue Gen 2 valve covers (clear aftermarket rockers on Gen3), no core, new
powdercoat, never installed since coating $350
Good used Gen 3 Stock lifter set $40
New stock T-stat $5ea (have a dozen at least)
PS line from pump to fan $40
Gen 3 AC bracket $10
Status
