Trainman
VIPER POWERED Join Date: Jun 2006
Member #312
Trainman's Garage
Made two passes, not bad but not great either. I think I have an issue, I'll explain in a minute. My two passes were as follows:
Run 1: 1.667 60', 1/8th 7.533 @ 93.84, 1/4 mile 11.775 @ 116.80.
Run 2: 1.660 60', 1/8th 7.552 @ 92.62, 1/4 mile 11.826 @ 116.16.
Here's the issue I'm having and it started last time out (Feb 9th, all 5 runs) the truck is starting to SCARE me on the high end and each shift. It is starting to "walk around" or drift all over the track, especially in 4th gear, sort of like wanting to fishtail all over the place. The truck wants to nosedive to the left and the rear end wants to come around to the right, also the truck is pulling to the right. It has been very nerve racking to stay in the throttle at 117 mph, and then when I let off to shut down, I almost loose control, again the tail wants to walk around me on the right side. I talked with Brad today and we think it might be an issue with the rear end, Something broken and not delivering power to each wheel equally? What do some of you experts think could be going on. I need to solve this before adding another 200 rwhp with my engine build. The truck is an 04, could I need a front end rebuild? It has 67,000 miles. I think I'll have someone look into the rear end (spider gears, clutches, etc.). I've noticed my times are about .1 to .2 slower and my MPH is off by about 1.5 to 2 mph. The last time I lost speed the spider gears were broken, costing me about 20 rwhp (we discovered that on the DC Performance dyno). But I didn't have handling issues at that time. Any input is appreciated.
I also had fun driving the Black Camaro again. The owner rebuilt the engine, upgraded the rear to ZL1 3.73 gears and had some MT ET street radials. When I got there I saw him run an 11.59 @127 (last time on street tires he ran 12.49 @119). He saw me and said "my driver mod is here" and asked me to take a run in the car. OK , the car felt real smooth and not that fast at all.....but the time slip said different....I ran a 10.74 @ 134.78mph.....wow. Nice.
I also had a younger kid with a supercharged 6.1 Challenger ask me to drive his car. He had Nitto radials, said it was bogging bad @ 2500 rpm , I also asked him about the tune, max hp dyno rpm, redline (he thought it was 6400-6500). Well I didn't run very well, I tried to do a 2nd gear burnout and the car stalled twice, I left the line @ 3000 and it wheel-hopped bad all the way through 1st (spinning) , the rev limiter was about 6250 so I hit the rev limiter twice during the run (in 1st and 2nd), so the car went 13.17 @ 116+. I wasn't very proud of myself, but the car was very different and hard to drive. With a little more seat time I could probably put the car in the 11's. I told the owner he first needs to cure the wheel hop issues and get some better tires (Nitto's suck). He also needs to strengthen the stock axles and add a Line-Loc.
Pretty fun and scary day to say the least. Those runs will probably be on video. Thanks again Brad!
Member #312
Trainman's Garage
