Dyno tuned.CAI, cat back, venomous pulley
Discussion in 'Dyno Stuff' started by dcapita, Mar 14, 2013.
  1. dcapita
    dcapita Full Access Member
    65
    Dec 26, 2012
    St. Louis
    That's it for the mods. 05 quad cab. Wasn't expecting numbers this high or as much gain. Didn't gain that much peak power, but at gained over 50hp in the mid. Was really fat down low and lean up top. Pretty happy though, VERY big SOTP difference.
  2. Brat
    Brat Active Member Supporting Member
    17,857
    10
    May 29, 2006
    wesley chapel,fla.
    O.K.what are your numbers?
  3. caveman
    caveman Well-Known Member Supporting Member
    7,508
    36
    Jul 20, 2011
    Western Colorado
    Big gains, what were your numbers?
  4. dcapita
    65
    Dec 26, 2012
    St. Louis
    Sorry, pic did not go through. Here it is. 464hp and 484tq before. 466hp and 511tq after.
  5. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    Good deal! You posted the other requested items right here. ^^^^^
  6. dcapita
    65
    Dec 26, 2012
    St. Louis
    May be able to see this one better
  7. caveman
    7,508
    36
    Jul 20, 2011
    Western Colorado
    Good numbers. Who tuned it?
  8. dcapita
    65
    Dec 26, 2012
    St. Louis
    Ben Craven @ Craven Performance in O'Fallon MO
  9. caveman
    7,508
    36
    Jul 20, 2011
    Western Colorado
    Would you mind sharing how much it cost? Many new members are interested in having a dyno tune done and knowing how much you paid might help them to make a decision. :)
  10. viperhauler
    18,950
    44
    Jul 27, 2008
    those numbers seem WAY high - especially for a mustang dyno... i'd figure 10-12% more if it were a dynojet, which would make it even more unrealistic...
    no doubt you'll feel the seat of the pants difference, especially if the tq management was removed, but i don't believe those numbers are accurate...
    but dynos are for tuning anyways...
  11. 505'sFastestViper.
    505'sFastestViper. Full Access Member
    13,813
    Apr 26, 2007
    Farmington, N.M.
    Same dyno before and after? I'm on my phone and didn't open the attachments.
  12. viperhauler
    18,950
    44
    Jul 27, 2008
    the graph seems overlaid, but the times are less than 11 minutes apart...
    it's doubtful you'd install a catback, cai, pulley, and an sct in 11 minutes, so i'm not sure how that translates...
    to load a tune takes about 5 minutes by itself, and that assumes there's no adjustments needed after the first "try"...
  13. caveman
    7,508
    36
    Jul 20, 2011
    Western Colorado
    Yep, same dyno. The numbers are usually high, but the gain in performance will be obvious on the track.
  14. viperhauler
    18,950
    44
    Jul 27, 2008
    i'd expect the most power to be gained overall to be around 20 hp with those mods...
    but you may see more in the mid range, for instance, over the entire length of the graph...
  15. VENOMOUS1 RACING
    12,751
    2
    May 15, 2009
    Wacko Waco,TX
    I'm sure he's about 50 ft lbs higher with those mods. No doubt :) Translating into 30 or so at the wheels ;-)
  16. caveman
    7,508
    36
    Jul 20, 2011
    Western Colorado
    The graph shows he picked up 2 peak horsepower and 48 ft pounds of torque. Sounds legit to me. Base dyno numbers are retarded anyway. It's the gains that should translate to performance.
  17. viperhauler
    18,950
    44
    Jul 27, 2008
    i think the ratio of gain could be there, but i think the baseline is about 50 too high...
  18. caveman
    7,508
    36
    Jul 20, 2011
    Western Colorado
    Thanks for your opinion. It's always good to know why people feel the way they do. :D
  19. viperhauler
    18,950
    44
    Jul 27, 2008
    [​IMG]
  20. dcapita
    65
    Dec 26, 2012
    St. Louis
    the cost of the SCT tuner itself (I already had one) I think they are $375, plus $110 an hour for tuning on the dyno. took 1 hour
