fuses?
crzyviper
buffalo ny
So installing my radio I ended up pulling it back out forgot antenna then when putting back in I heard a arc. Now radio wont power on and my interior lights only work when truck is on. I can't find a radio fuse any ideas?
I don't know if this helps but sometimes the "Memory" fuse is the radio
Just looked I don't see no memory fuse. I used a test light and all fuses have power
a wire probably got cut and broken. the fuse may have failed to pop. you need to remove the radio again and find the wire that arc'ed.
its the IOD fuse located in the PDC. it has a white tab over it that you will need to pop open to replace the fuse
After you correct the short that is
Got it all figured out helps being able to have day light to see haha but fuse 51 did it
