I may need the hydraulic fan assembly. If anyone has upgraded and still has their OEM one I may be interested. Ill find out this weekend after more investigating. Got a slight vibration started after putting in new radiator.....my fan has some nicks on it. Should the bearings in the fan move? PM me if any of you have one. Thanks SHU
Yessir, bearing in fan will move around. Usually at bottom when engine off. Nicks in blade aren't a concern but any cracks, missing pieces, or loose mounting will cause vibration.
I like the 2 fans myself. but still not bad. And the JTSVP one has PS line included. Price comes out bout the same in the end tho.
I did a ton of fan research years ago, and the one Justin uses is a OEM Dodge piece used on different vehicles and pulls a lot more air than the other aftermarket fans on the market (which is what Tony's uses).
