Paint question?
You use a fuel line quick disconnect tool, get the aluminum ones and remove the line on the drivers side rear fuel line, then you can remove the intake w/o pulling the injectors...
Aren't supposed to depressurize the system first? That was more or less where I was going with my vague question.
Passenger side fuel rail has a port that you can bleed the pressure off of.
Yeah, sorry, it's like a tire valve stem, just depress it with a rag around it to catch the little bit of gas that will come out......
