LORD CHAVEZ
When i cam my truck do i need a special tune to make run? And wat cam do yall recommend
The MOPAR cam is not worth doing. Contact rottenronnie, Venomous1 or Justin and they can set you up with a custom cam profile to suit your needs.![]()
Anyone know what one should expect to pay for cam and install? also any other parts needed besides a tune? been going back and forth on this mod or not. Cant beat the sound of a cammed out v10
A cam install on our trucks is pretty labor intensive. Book time is around 15 hours if I remember correctly. Cam, lifters, fluids (oil and coolant) and gaskets I would guess in the $1500 - $2000 range depending on the labor rate of the shop you choose.
Never driven or seen anything other than Mopar but mine seems fine. Real nice loaping idle. :dontknow:
The MOPAR cam is worth 8hp if I remember. A custom cam can be ground to suit future mods. As an example we did the Striker cam in mine a year before I did the Striker heads. If a future mod was to do ported heads and intake, you would want the proper cam for that.
A cam change is a total pain in the butt, Do it one time only!
Yes you need cam, springs,pushrods, plus gaskets, fluids, and any unforeseen necessities like tensioner pulley, idler pulley, spark plugs, yes a tune for a real cam.
There are Mopar and Comp grinds that are close to stock specs and can get away with those parts. A cam that'll make power is going to need springs and pushrods.
Wasn't there a conversation about weak stock springs?
