VENOMOUS1 RACING
Ok two options really from your body man/Viper Nut.
Break the handle (cheap plastic and usually break anyways and get you a paintable one
Option two, try this first as option one. Lmfao
Under tailgate and rear of bed you should see two wires. Usually come out Tailgate drain and snake under bed, into drivers kick panel (left foot area that includes scuff plate on entryway.
Bring a 12 volt battery and jumper cables and start at the tailgate to see if the problem lies in wiring to cab.
Momentarily touch cables to wires and remove. Do you hear actuator??
Reverse cable positive and negative to lock/unlock. One way will lock, swap pos. for neg. and now solenoid/actuator will unlock. Not even sure a locksmith could get in. Just looked at mine
