Clutch options?
gatorowned
Jersey and Florida
Okay...my clutch is starting to get rough. My pedal comes almost all the way out before the truck moves forward. No noise or anything or smell that I can tell...but think the 39k miles is a bit low for needing a clutch already since I am not hard on it. In any case...what are my best options for a new clutch? I have checked on here for some.
Any help is appreciated
Maybe try bleeding/flushing with new fluid, seems to fix quite a few problems with the clutch on these.
Do try a bleed for sure, but if your in 6th at 65-70 and give it gas and if it slips you'll know then. ;)
Centerforce I swear by and use in our installs unless its a high HP build then we go twin disc. :rock:
Whatever you do, get the lightest clutch feel possible. I freakin hate my spec 3+
Im doing with a lite dual disc next.
Thanks guys. I was thinking bleed first as well...but took the advice and have it gas while in 6th gear at around 70mph...and it felt like it was slipping
