08 srt10 swap?
jlange101
if i would get a 2006 would the rear end just be a swap or would it need custom fab also and are the mount locations different from the stock 4.7 and what other problems would i run into would i also be able to just switch the tranny crossmember to bolt up the t56 i would like to do the quad cab manual swap that i found in the forums thanks for any help in advance and also if i would find an 05 or earlier instead would i be able to use an 06 harness and pcm and to simplify my wiring
Would love to help you as I'm the originator of the SRT-10 6 speed swap, but I'm having trouble figuring out exactly what you're asking and needing bro.:dontknow:
just for starts i just wanted to know if i get a 06 donor rc do i need to move the engine mounts and what will i have to do for electrical
Everything bolts right up, bro! Guys do this swap like every day! All the electrical is totally plug and play! (I'm tired of answering these questions the same way every time, so I thought I would try something new :D)
In the title he mentions a 2008. And then a 4.7 in the post.:dontknow:
sounds like he wants a viper swap from an 05-06 into an 08 4.7 ram.
you'll spend more money and aggravation making it all work then you will just finding a real 10.
Have you thought about a 4.88 gear swap?
How much Hp will a cam swap give me and which oil is the best?
Removing the cam is a great way to take some weight off the front end. You'll probably pick up .1-.2 in the 1/4 from this mod alone.
4.88's on work on the streets. Don't confuse the new guy.
Not true. Caveman says it's a direct bolt up. He should know, he is THE Caveman.
