better to get cometic's. small compression bump. you will notice the difference.
but those aren't gen 4 thickness correct??
Do i have to have new head bolts?? If so, how about these?
2004 Dodge Viper Cylinder Head Bolt - Auto Parts Warehouse
Felpro Cylinder Head BoltPart Number: FPES72209 Manufacturer Number: ES72209 .
Felpro Cylinder Head Bolt Felpro Cylinder Head Bolt
$45.99
List Price: $54.27
Availability: In Stock
FELPRO CYLINDER HEAD BOLT SET -- Includes head bolts with washers; A complete set of the highest quality head bolts and hardened washers; Cold formed to ensure molecular integrity; Heat treated prior to thread rolling and machining; Its reduced diameter bolt heads eliminate the need for valve train removal and facilitate cylinder head re-torquing; With 1-year Felpro limited warranty.
Fit Note: Car
Product Fit: Direct fit
Quantity Sold: Set
Anticipated Ship Out Time: 1-2 business days
Fits the following 2004 Dodge Viper submodels:
2004: SRT-10; 10 Cyl 8.3L; "GAS, FI, Naturally Aspirated, VIN Z"
DAMN! this thread bothers me! the head gaskets are not a problem on these trucks! If the engine overheated it could have a cracked head . be prepared! something is amiss!
Well, after investigation, the ONLY thing that the mechanic could find, was that the 10th bolt was not as tight as all the rest. When he checked everything for trueness, he said that he lays some tool across the surface, takes 3 measurements, adds and then divides by three, and it has to be below a certain number, annnnnd he said he couldn't even get a measurement off of mine because they were that perfectly true!!! Have to say I'm amazed! Can't wait to have it back. Should be this week hopefully!!!! :burnout::burnout::burnout:
