Doms 98 Viper JMB Procharger Build
JMB Justin
Preferred Vendor
Hillsboro MO
Starting a new thread for Doms 98 Viper Build. Goal is a easy 9 second time slip capable car, set up for no prep street racing. So far:
-Powdercoated Intake manifold/Valve covers/T-Stat housing
-New cam/springs/retainers/locators/valve seals/pushrods/1.7 rockers
-1 3/4" Stainless headers
-100% New fuel system inc JMB Billet rails
-HID headlights and Fogs installed
-ATI balancer and 10 Rib blower crank pulley installed
-New 10mm plug wires and separators
-New large radiator and 99+ fan module
-Line lock installed
-Diff fluid changed
-JMB F1C Blower kit is mostly fabbed up, bracket templates are done and at waterjetter to be cut from 1/2" 6061 plate. Intercooler is 95% and all piping is 100% done and coated.
-Starting on Stereo upgrade
-Bogart 15" wheels fitted and waiting to be coated
-Custom brake and SS brake line setup for 15" wheels
-Corsa catback and JMB SS midpipes
More to come...
Did you guys pin or key the crank snout? Looks good.
What are your guys thoughts on these different air filter setups? I want to have a few different options and I am going to dyno all of them to see the differences. Tell me what you love and what you hate, what you would want to get if you bought a supercharger kit for your viper.
I like the one that looks like the K&N. Second would be the Scrub Bag. With the others, it looks like you would be taking a chance of objects getting into the S/C. Just my 2 cents.
What are the size of the rear chrome wheels that you had on it while it was on the lift??
They look deep.
Work looks great. On my personal car I would more interested in running the actually filter looking one or the one with the scrub bag. First mesh one looks cool second one with the bigger screen I am not a fan of looks cheap. Just my 2 cents
Engine compartment looks clean and classy, reeeally nice work !!!!
K&N is a lil boring although you can't go wrong with it....but you're gonna want to see the impeller blades peeking out through the scoop, so the bug catcher would be the way to go.
No bad choices, it's all good stuff !!
You should look at Pro Volute from steve morrison for your intake, Big hp increase due to some vary interesting fluid dynamics
I like the K&N look. Or the tighter metal mesh grille.
Amazing work Justin.
