Belanger + high flow cats + B&B ?
Sammy11
Belgium
does anybody ever build a B&B catback at Belanger long tubes + high flow cats on a 2006 QC ?
and if so , did you need the mids from B&B along with the catback to mount ?
I have an RC, but my B&B cat-back had to be modified to fit with the Belanger LT + catted H-pipe.
You just need mid pipes to meet up with b&b. Unless you already have full 3" from the cats to the magnaflow.
Sammy,
B&B manufactures catback system that bolt up to their own headers with midpipes and also to the stock setup.
So even if it will not bolt right up, a welder could easily help you with fitment for a few dollars.
Sammy looks like you have 3" mids. That small extension after your mids is for qc. Because of longer truck. I am pretty sure you just need that cat back for a qc hope this helps
Those are stock extentions. So u have 3" mid pipes going in the stock 2.5 piping then back to a 3" exhaust. Just cut it off where the mid pipes end and have a exhaust shop make u 3" extensions.
ok , or i'll order the mids from B&B together with the catback...:D
