funny mine are on also for a long time now and have switched out wheel sensors twice. Still on. I think it has to do with the tipm module. Along with that my left front turn signal doesn't blink and has no power going to it. I also replaced the front hubs with new ones from rock auto and put all new brake fluid in also. Me brake fluid turn black and dirty after only about 300 miles of driving and I wasn't driving hard either.ABS and BRAKE light is on...what is the cause?
Mine comes on every now & then. Took it to the stealership (under warranty) & they said they couldn't make it come on, so I would have to bring it in while the light was still on. Mine usually goes off after turning the key off & back on a couple of times.
what's the best way to fully evacuate and replace every drop of brake fluid in the system?Yeah this is mostly an 06 thing I've noticed. They also have the glitchy tach issue as well. Hope you find the cure
I tried replacing all that. Bought the rotors and rebuilt calipers from tony and put ceramic pads on. Bought new hubs also at same time and didn't help. Now my abs light is on also but that happened recently.It is fixed. I took it to jtsvp and had tony put on some needed wheel hub bearings, rotors and pads. I highly recommend the rotor and pad combo that tony has. It seems to be the perfect combo for out 10's.
