Turbos!
budget 3-4k, can it be done, probably, our last twin set up just the turbos were 6k
heads ported correctly alone 4k ish
mods aren't cheap , just the tuning will run a good bit, don't skimp on that;)
Hm ok, good to know. Is the 4k for ported heads on new ones or on mine?
Ok your going to need around a 78mm -88mm turbo. Manifolds will have to be custom made. You don't want to push a stock pump that hard and wouldn't make that kinda power being F.I. I would go air to air intercooler. You can actually use a ram diesel intercooler will bolt right up. Not the best intercooler but it will work.
78-80mm? Got it.... yea that makes since about the fuel pump. Ive heard a few times about using a Diesels intercooler for air to air
78-80mm, will never spool up until you are on the topside of 3rd (about 80mph) then the rath of satan will spin the tires and send you hurling over the nearest embankment, squealing like a little girl!!!! If you survive the crash you will put that truck up for sale! just like all the other high hp trucks!!.....except one...... He hasn't driven it yet with the twins......Dom.... where is that truck at .................:D
Lol.. 78 do seem a bit big. But once again i dont know wat size is best for these motors. I would like some top end but not have to wait till 3rd lol
$3,000-$4,000... never going to happen! I don't care if you are going N/A, S/C, or Turbo(s), you are never going to build anything reliable in the 600whp range for that kind of money. I had the same pipe dream at one point... then I spent twice that amount!
That is not to big. You have to remember out motors are huge 8.3l to be exact. Hell I had a 76mm on my 4.6 mod motor. If I go turbo I will be using a 88mm. The size of the exahust compressor housing will determine how fast it spools up.
Hm true..
Well thats rude! Way to kill my little hope... lol well im not gonna be buying them all at once, ill start with some parts here and there and see where it goes Budget wise. But atleast ill have some what of a budget ha.
